Landcruiser lj70 [creepycruiser]
Victor
Well, i've asked y'felas about some stuff, and thought to myself, why dont i do a build topic here too, and show my toyota? :P
Well, i've had it for a couple of years, now, so will be a long post, hang tight...
As it stood whe i obught it (minus the winch)
7480626150_e123ddb301_c.jpg20120701_180728[1] by Vc1r, on Flickr
7480629142_ccc76a5bb7_c.jpg20120701_180704[1] by Vc1r, on Flickr
Removed some witres from an old alarm system!
7521492908_73bda9aaa2_c.jpg20120706_153900[1] by Vc1r, on Flickr
Booost gauge went in!
7521495382_16cea9f62d_c.jpg20120707_185255[1] by Vc1r, on Flickr
Winch and tow-hooks added.
7591241834_16a06761d0_c.jpg20120717_180757[1] by Vc1r, on Flickr
Strap holders, later scrapped though..
7591244830_c1082ae456_c.jpg20120717_180811[1] by Vc1r, on Flickr
Storage
7591251426_6cf3d1f8f4_c.jpg20120717_180840[1] by Vc1r, on Flickr
Dented the drivers side fender REALLY good on the first big meet, this is after "repair"
7637135718_a471d92557_c.jpg2012-07-24 15.43.54 by Vc1r, on Flickr
7637133736_70eddf1763_c.jpg2012-07-24 15.44.02 by Vc1r, on Flickr
Tight with new rubbers ;)
8033088907_4d51cb1f82_c.jpg2012-09-28 12.30.37 by Vc1r, on Flickr
That feeling =D
8033088250_3efe1742eb_c.jpg2012-09-28 10.47.59 by Vc1r, on Flickr
35" Maxxis Creey Crawlerrs on what i later found out stock height lj70 =P
8033087360_5ee136e84c_c.jpg2012-09-28 11.28.02 by Vc1r, on Flickr
8036096734_c9edbc2c5b_c.jpg2012-09-29 15.37.05 by Vc1r, on Flickr
8036091151_e532ca0698_c.jpg2012-09-29 15.37.39 by Vc1r, on Flickr
Rebild of front axle...
8190332145_cc2e3d6d53_c.jpg2012-11-16 16.12.03 by Vc1r, on Flickr
yummy
8194000028_7100a47148_c.jpg2012-11-17 13.02.44 by Vc1r, on Flickr
Better =D
8192910291_0751026698_c.jpg2012-11-17 13.59.12 by Vc1r, on Flickr
8193996054_a61ef52267_c.jpg2012-11-17 15.03.43 by Vc1r, on Flickr
heavy motherBEEEP to lift with everything intact except for wheels...
8192907047_5d28095c55_c.jpg2012-11-17 17.18.34 by Vc1r, on Flickr
Had a slight mishap one winter, tried to go under a small motorcycle bridge, and the ice cracked, ended up nearly stuck as winch was broken...
8258133948_e7cd82f38f_c.jpg2012-12-09 15.21.10 by Vc1r, on Flickr
8257063485_8c62746ac7_c.jpg2012-12-09 15.19.18 by Vc1r, on Flickr
Fitted 2 small Bosch lights with 55W xenon..
8297137858_2cc6b562c8_c.jpg2012-12-21 13.53.18 by Vc1r, on Flickr
Oh lala!
8297136692_1ea08d4483_c.jpg2012-12-21 13.59.19 by Vc1r, on Flickr
Winch parts...
8296085787_3d4d331754_c.jpg2012-12-22 14.06.24 by Vc1r, on Flickr
Stock vs new exhaust...
8325248787_324442eaa7_c.jpg2012-12-29 13.12.18 by Vc1r, on Flickr
Bottleneck... did leave it though...
8326305470_fe2a3810c4_c.jpg2012-12-29 13.12.27 by Vc1r, on Flickr
Aint pretty, is tight, but does the job!
8325244551_7e6e37d57f_c.jpg2012-12-30 11.20.07 by Vc1r, on Flickr
3" from turbo..
8326301202_0b3c5d5836_c.jpg2012-12-30 11.20.12 by Vc1r, on Flickr
That's all there is to it!
8325241829_f827ef20f8_c.jpg2012-12-30 15.45.34 by Vc1r, on Flickr
35"'s doesn't rub! WIN!
8326298762_3bdd419567_c.jpg2012-12-30 15.45.45 by Vc1r, on Flickr
Fitting of ome +3"
8350060642_e124bcf15d_c.jpg2013-01-05 14.24.25 by Vc1r, on Flickr
8353006341_5c00208691_c.jpg2013-01-06 13.53.43-4 by Vc1r, on Flickr
Rocksliders..
8669316912_201bf7c7f2_c.jpg2013-04-21 19.22.27 by Vc1r, on Flickr
It does have supports in the middle, just not in this picture ;)
8669323460_a93ef4f80e_c.jpg2013-04-21 19.22.15 by Vc1r, on Flickr
8690104798_3d7486998f_c.jpg2013-04-28 15.20.18 by Vc1r, on Flickr
Ended up needing to reweld the box profiles previous owner "welded" on instead of uhhh... that below the doors... XD
8704421608_9e22ac7572_c.jpg2013-05-02 16.55.05 by Vc1r, on Flickr
8704421070_7a34906208_c.jpg2013-05-02 16.54.58 by Vc1r, on Flickr
8704420462_6475137634_c.jpg2013-05-02 16.54.45 by Vc1r, on Flickr
Air intake, and some louder horns as old ones were toast..
8924333015_327a86991e_c.jpgUntitled by Vc1r, on Flickr
Had a real bugger thinking of a "suspension" for the exhaust... tried several, ended up with this one, still going strong year and a half later ;)
8979675576_800781867c_c.jpg2013-06-07 13.38.53 by Vc1r, on Flickr
crank case ventilation to intake.. Drilled M12 bolt..
9239775281_23bbcf339f_c.jpg2013-07-06 11.37.16 by Vc1r, on Flickr
To a coke bottle... Later changed for a nice aluminium tank..
9239768957_c160fcb3a0_c.jpg2013-07-06 11.37.11 by Vc1r, on Flickr
Decided i was fed up with the old front bumper, sticking out way to much, so did a new one.. here with the frame cut off and winch plate welded to the chassis.. 10mm...
9359703422_c30974212b_c.jpg2013-07-22 16.57.15 by Vc1r, on Flickr
In hindsight i should've made this hoop a bit higher and angled it out more as it is a squeeze to get the winch in and out now...
9369557957_eb65b04cbb_c.jpg2013-07-26 12.03.41 by Vc1r, on Flickr
finished product, also cut away some metal under the headlight bezels..
9375155923_9b68f6bf40_c.jpg2013-07-27 14.18.31 by Vc1r, on Flickr
But i still manage to get dirt into the bumper sometimes, i think i need the front wheels further forward =D
9377935394_6c620db409_c.jpg2013-07-27 14.18.39 by Vc1r, on Flickr
New cooler, steering damper
9504806430_5d98ce0424_c.jpg2013-08-12 19.16.55 by Vc1r, on Flickr
EGT sender, redrilled a hole for the heatshield on the downpipe and fitted it there...
9631466794_32ea73faf7_c.jpg2013-08-30 15.55.46 by Vc1r, on Flickr
A small ball bearing ball i lost when rebuilding the steering box... Was so lucky that i found an old one same size in an old box of dads! talk about luck!
9688869238_4c63828eda_c.jpg2013-09-06 12.44.20 by Vc1r, on Flickr
Found a pretty much brand new spare tyre..
10209809834_8bd1ae87ae_c.jpg2013-10-11 12.59.47 by Vc1r, on Flickr
Started redoing the package space.. removed all asphalt mats and paint...
10209818904_001f390199_c.jpg2013-10-11 16.43.07 by Vc1r, on Flickr
Gonna be 2 boxes on each side over the wheel wells like this, opens on top, and then a box in the middle for the spare, so that i get a flat, raised floor...
10228654615_a46552f9ba_c.jpg2013-10-12 16.54.08 by Vc1r, on Flickr
Reinforced with lid on...
10249942684_a254dc4f4c_c.jpg2013-10-13 16.25.44 by Vc1r, on Flickr
Fucked up and put he hinges on the wrong side...
10250155823_782e2bd9ee_c.jpg2013-10-13 16.25.53 by Vc1r, on Flickr
10330902785_5f12e83926_c.jpg2013-10-17 16.32.37 by Vc1r, on Flickr
Ugly
11581951964_a30634da3b_c.jpg2013-09-08 13.03.00 by Vc1r, on Flickr
Nice =D Sourced a radio bezel...
12015349515_e70cbe427c_c.jpg2014-01-18 14.52.10 by Vc1r, on Flickr
Rot...
12700987235_785aecdc0f_c.jpg2014-02-21 13.53.08 by Vc1r, on Flickr
Yuck..
12701463994_2e674ed57d_c.jpg2014-02-21 15.34.30 by Vc1r, on Flickr
Getting there...
12700961985_6904c65e95_c.jpg2014-02-21 16.17.51 by Vc1r, on Flickr
12701101163_1e6053e498_c.jpg2014-02-22 15.07.22 by Vc1r, on Flickr
12701094153_4d7d88409f_c.jpg2014-02-22 15.07.30 by Vc1r, on Flickr
12700904105_48da2d6c1a_c.jpg2014-02-22 16.02.31 by Vc1r, on Flickr
*drool*
13468597353_9cfd323d07_c.jpg2014-03-28 16.08.36 by Vc1r, on Flickr
test of rear locker, no bueno *sad*
13825715475_b6a465c2d7_c.jpg2014-04-13 14.22.27 by Vc1r, on Flickr
35" deep... on one side :P
13826053324_8b90de6b7b_c.jpg2014-04-13 14.22.31 by Vc1r, on Flickr
Control box for kompressor, lockers, switch for winch, and battery kill switch...
14464709565_4897146e5b_c.jpg2014-06-13 18.01.31 by Vc1r, on Flickr
front locker going in...
14278251357_0473082a05_c.jpg2014-06-19 18.37.12 by Vc1r, on Flickr
Brake servo decided to crap itself... Full of brake fluid... got a better second hand unit...
14333056018_caa64e2acb_c.jpg2014-06-27 15.26.42 by Vc1r, on Flickr
Oops! To strong shampoo!
14590226918_ab523dc115_c.jpg2014-07-29 15.44.29 by Vc1r, on Flickr
Just kidding! New paint and stickers added!
14794478345_6bd79ee320_c.jpg2014-07-31 16.01.39 by Vc1r, on Flickr
14791343351_5dc08d811a_c.jpg2014-07-31 16.01.52 by Vc1r, on Flickr
14791338271_648b3c4f58_c.jpg2014-07-31 16.02.15 by Vc1r, on Flickr
14607757800_0cb173d1d8_c.jpg2014-07-31 16.26.44 by Vc1r, on Flickr
We started building a small trial section...
14943925871_52e5b563e4_c.jpg2014-08-17 12.15.58 by Vc1r, on Flickr
Around 30 some degrees droping into what will be a puddle of water...
14946997015_26d0b4401b_c.jpg2014-08-17 12.17.19 by Vc1r, on Flickr
Did not want to go any further... I think i had around 30 degrees there too...
14943893751_90f36f3e07_c.jpg2014-08-17 12.20.12 by Vc1r, on Flickr
Hanging loose...
14760327968_81c9683012_c.jpg2014-08-17 14.57.58 by Vc1r, on Flickr
Some rocks added to trial section...
14959531699_2d4949de0a_c.jpg2014-09-04 18.44.50 by Vc1r, on Flickr
Was well time to replace the bushings!! This is how it came out when i dropped it...
15246503516_662423d340_c.jpg2014-09-10 18.40.25 by Vc1r, on Flickr
Much better!
15266399161_9c25935965_c.jpg2014-09-10 19.53.38 by Vc1r, on Flickr
And now we are up to date, that is the journey from start! Next trip will hopefully be on saturday!
Damn fine landcruiser, the 70 is defiantly my favourite cruiser, keep buying other cars and haven't been able to bring myself to sell mine
Thanks guys!
Had a great day out today, and with the new radius arm bushes the 'yota handles the road perfectly! Well.. Perfect is a strong word, but you get the idea ;)
I do believe though that i get more bodyroll now, and when i tried flexing the bushes while in the vice they were pretty soft, and old ones were, well, hard... Initial test drive was almost a bit scary as i wasn't prepare dfor it =P
Where did you get the bushes from? Are they genuine? :think:
The ones I recently fitted to my rear axle are now completely shot! :doh:
I think its because I need a longer/adjustable panhard rod as the standard one is too short and is constantly pulling the axle over and putting strain on the radius arm bushes. :think:
I got the bushes from a swedish site.. And they are not genuine...
GET SOME BLING YAO.
Just scored a set of these, brand new for 5999 SEK, which is about 500GBP, regular price is 651GBP :dance:
I've been looking at this set for quite a while now, and when i saw that he lowered the price i couldnt resist :icon-biggrin:
Started changing the rims out today.. With some great help from Dad we managed to get the second tyre off and onto the new rim in just under an hour, not to shabby taking in consideration we dont have any machines for the job! All manual labour!
15717090856_4a9ef1bd3f_c.jpg2014-11-08 16.28.35 by Vc1r, on Flickr
A bummer though, the first rim we changed leaks in the weld between the ring and rim, I can hopefully sort it out with the place i've bought them from, but he sounded pretty adamant on taking them back, refunding me, fixing them and then resell them again... Not something i want to do...
Well. everything played out great with that rim that was leaking! Got a smaller refund from the company after some talking about it..
It turned out to have 2 tiny holes in the weld, one of them we got airtight in 2nd try, and the second one after 4 tries and some chemical metal. i was sooo frustrated when it still leaked after the 3rd welding and we had to take the rubber off again.. Anyway, with that sorted we took off the front wheels aswell and changed them.. Under 1 hour to change both rims this time, so we improved our work all the time! Remember lads, that's wrestling 35" rubber off of rims BY HAND, no machines at all ;)
That was yesterday, today i got the wheels fitted to the car, and gosh golly! What a beauty!
15183506793_6671bbbbb4_c.jpg2014-11-16 10.41.05 by Vc1r, on Flickr
15183512743_494dcfbd43_c.jpg2014-11-16 10.40.40 by Vc1r, on Flickr
15802961825_3b9e60f023_c.jpg2014-11-16 10.40.13 by Vc1r, on Flickr
15617561698_f9bc56dfae_c.jpg2014-11-16 10.40.02 by Vc1r, on Flickr
I do however need now to cut the rear fenders aprox. 5cm and the front fenders 7cm to not have the tyres catch on them when articulating.. also (which i still have not done since fitting that lift kit) is to adjust the panhard rods as the axles is to far over to the drivers side.. adjustable ones would be nice, but i think i'll drop the mount on the chassis..
Great work! :thumbup:
I bet that was some workout taking all those tyres off and on! :sleeping-sleep:
I know how frustrating it can be when you weld something again and again and it still wont hold air. Thats where TIG is awesome! I take it you were using MIG? :think:
Yep. never welded Tig, and dont own one either.. MIG works fine for me =P I've welded up to 10mm thick steel plates with it so it works fine for the stuff i do =P
Garage weekend! Gonna drop the tranny, and change the rear oil seal on the engine, throw-out bearing, and clutch!
Oh, and i got a nice package delivered today aswell from the states, 3 days for shipping from Salt lake city to Sweden is in my opinion pretty epic. Also, for once the predicted delivery was spot on! Awesome as fuck!
15658517620_b9b33cf7c0_c.jpg2014-11-21 16.24.32 by Vc1r, on Flickr
Is that a transfercase disc hand brake? :think:
Any chance of the link please?
Just been looking at their website but cant seem to find it. :thumbdown:
I will be very interested to see how well it works, I would love one for mine if it works well. :icon-biggrin:
The X-ENG one I brought never worked properly. :doh:
