LED headlamp bulbs
chapel gate Oct 7, 2016
  1. chapel gate
    chapel gate Well-Known Member Supporter Promoted Company I am in england
    2,934
    1,658
    113
    Map
    Raise the beam and I get flashed frank. Mot tester also moans. Im also running osram night breaker bulbs, there better but still no good.
  2. Roger
    Roger Well-Known Member Supporter I am in uk
    222
    116
    43
    Map
    Usually Im more than happy to have survived an off-road weekend with glass and lens in tact....... :grin::grin::grin::grin:
  3. Lund
    Lund Well-Known Member I am in norway
    238
    36
    28
    Map
    don't know how you fitted yours mate, but mine are not letting any water through the rubber boot cover or whatever they are called.
  4. clivehorridge
    13,901
    3,848
    113
    Garage:
    Map
    chapel gate likes this.
  5. grantw
    grantw Well-Known Member Supporter
    1,808
    222
    63
    Map
    I can't recall if the inners are H1 or H7.
    Definitely worth while just for the smile factor. I'm very happy with mine, I don't even feel like I need dedicated riving lights or a bar ... but I will still probably get these as I do love lights :)
  6. Beau
    Beau Well-Known Member I am in guyana
    1,789
    194
    63
    Map
    I have a question regarding these bulbs.... At the moment I'm running some HID's in my place of my H4 regular halogen bulbs. The problem is, because there's no projector, it does produce some glare on oncoming traffic. They are very bright and when I had the truck in the UK, it passed the MOT's fine. This kinda confused me as I was expecting them to fail.
    Are these bulbs going to be a similar situation where they're bright and good for driving but will they dazzle oncoming traffic? The 90 series lense is what's known as "fluted" where the glass design directs the light. So in theory whatever light is produced behind the lens should be cut off and directed forward. But this isn't happening with my HID's. I believe the 80 series lens is also fluted?
  7. grantw
    1,808
    222
    63
    Map
    Beau, I've done quite a bit of night time driving with these including through France & Belgium (with head light convertors) and I haven't been flashed once.
  8. chadr
    chadr Well-Known Member I am in england
    2,523
    249
    63
    Garage:
    Map
    I've had my LED bulbs in my 90 for around a year (maybe more I can't quite recall) and they have been literally brilliant. The low beam is amazing compared to a Osram/Philips 100%+ type halogen bulb. So the difference between a standard halogen and these LEDs would really be night and day. They've pasted the MoT without issue, though the cut-off is weak and I've never had any issues with oncoming drivers flashing etc.
    The minor drawback for me is that high beam penetration is weak - little more than low beam TBH. However I use high beam very rarely in my day-to-day driving, so it is not an issue. Even then, I would be tempted to get a decent light bar or driving lights to compensate for that if necessary.
    Once you have LED bulbs, I think the 90 (and 80s) weakness is the lense - these were never designed with these bulbs in mind so are not the most efficient in that respect.
    My other car has HID/Xenons and they are superb in every respect; very good low beam with a crisp cutoff, main beam reach will light up everything up to around 200ft quite clearly. I wish I had similar on the 90.
  9. StarCruiser
    10,032
    3,806
    113
    Garage:
    Map
    The problem with HIDs is that they don't have the arc that generates the light in the same place as a filament of an ordinary bulb so it is essential to have them fitted to not just lenses but complete headlamp units that are purpose made for them.
    The LEDs on the other hand are made to mimic the filament position and utilise the reflectors and lenses originally fitted.
    My MOT tester who I've been going to for years was pretty impressed with them but had to significantly lower the beam to get them to pass the viewer.
    The thing is, these have been superceded at least twice now so we are talking about lamps that are likely to be improved at each stage.
  10. Lund
    238
    36
    28
    Map
    I am well chuffed with my set, they are almost comparable to my Cayenne xenon lights (but only "almost" :) ) recently passed MOT with no comment.
    grantw likes this.
  11. Shayne
    Shayne Well-Known Member Guru
    10,764
    3,115
    113
    Map
    Both 80 and 90 series light lenses are fluted and its handy to know where deflectors go for driving on the wrong side of the road is clearly marked by a triangle in the glass . A simple thing but worth sharing if it saves someone a few minutes of head scratching .
    thelal likes this.
  12. clivehorridge
    13,901
    3,848
    113
    Garage:
    Map
    "... wrong side of the road..." are you insinuating something there Shayne...?
    Beau likes this.
  13. Shayne
    10,764
    3,115
    113
    Map
    As opposed to the right side of the road , can you believe there's some poor souls out there who simply can't grasp the concept because somebody has put their steering wheel on the wrong side as well :doh:
    clivehorridge likes this.
  14. chapel gate
    2,934
    1,658
    113
    Map
    Well, ordered a set of these last night:thumbup:
    grantw likes this.
  15. AlexanderVanBaelen
    AlexanderVanBaelen Active Member I am in belgium
    53
    20
    8
    Map
    I bought these two years ago based on a review on iH8mud:
    http://woodypeck.com/?product=new-h...ulbs-80w-bulb-set-4000-lumens-1-pair-of-bulbs
    I had been super pleased with them till I mounted them in a Nissan Micra two months ago to do the Mongol Rally this summer. I noticed that they are not really made to mount and unmounts many times and the main issue was that I had 4 of the 8 individual leds which got burned. Basically the bulbs are to be thrown away. On top, the ones I had have a fan and this seemed pretty rusty after a year.
    Could be that the set shown here is of a better quality?
    Anyhow, I was thinking how to upgrade the lights on the 75 and was doubting:
    - Buy new leds
    - Buy IPF inserts, HB Osrams and the wire upgrade mentioned in a post here
    Or maybe the best is to do a combination of both?
    In any case it is already great to read that people passed the MOT with these - a local mechanic mentioned me that they wouldn't pass in Belgium, but I am doubting his opinion now!
  16. flint
    flint Well-Known Member Supporter I am in great_britain
    914
    498
    63
    Map
    I fitted a pair of the H4 9600 leds from Steve at Woodypeck (the ones with the braided heatsinks) just under a year ago to my 95. After I fitted them, I went to my local MOT place just to check that I’d set the alignment properly and he was fine with them. I did have to fit resistors to get the high beam indicator to work (carefully placed as they get very hot), but they have proved to be a worthwhile upgrade over the Philips halogens I’d fitted before by quite a big margin. So far no one has flashed me on the road.
    thelal, chapel gate and Ben Stratford like this.
  17. chapel gate
    2,934
    1,658
    113
    Map
    why did you have to fit resisters flint? not over keen on that..
  18. flint
    914
    498
    63
    Map
    As far as I could work out, the high beam indicator circuit on the 95 needs to sense a certain amount of resistance to be triggered, which the leds don't provide. The leds work fine without the resistors, just no blue light on the dash. I’m not sure, but it might be a different setup on an 80.
    Xena and chapel gate like this.
  19. chapel gate
    2,934
    1,658
    113
    Map
    Hmm, anyone have a contact number for woody peck? The one i found via a search put me through to a furniture place..
  20. StarCruiser
    10,032
    3,806
    113
    Garage:
    Map
    CG, you have a PM. :)
Share This Page
    Dismiss Notice
