HID = High Intensity Discharge lamps. Known in the general electrical industry as Metal Halide lamps. Basically a contained electrical arc which gives off a huge amount of heat. These take a second or two to ‘strike’ or start an arc. Not so good for dim/dip to Main beam. Not easy to mimic a fillament lamp.
LED = Light Emitting Diode, instant lighting, lots of light out put for very little heat and good beam pattern as the LED ‘chips’ can be made into various shapes.
A little off subject here but I’m always confused by literature stating HIDs give off huge amounts of heat.
I’ve had mine fitted for nigh on 3 years now, and I can’t say they generate any heat at all.
The halogens used to project heat with the beam, you could feel the heat when you put your hand in front of the lense.
With HIDs, there’s no heat whatsoever (on mine) the lamps even get snow and slush build up on them and I have to stop every 5km or so to wipe off the inch of build up on the lense when its snowing heavily.
It’s their biggest draw-back IMO, that they project no heat. They dont even get hot at the back of the unit like LEDs do, theres no heat dissipating braids just a small alloy heat-sink.
Still confused... but the beam is BRILLIANT even after all this time
