Rob
Gav Peter said:I'm shamed to say I only managed to get one photo all weekend which was of Rob piling up one of the woodland hills...
And you didn't even manage to capture my front axle airborne
TonyS said:Hi guys,
I forgot to collect the maps in, will hopefully need them again, any chance of posting them back if you still have one?
Many thanks,
Tony.![]()
It has to be said, it was hilarious watching you two bumbling around the blind driving course demolishing it as you went!!!Jon Wildsmith said:...and then Toby (who had been watching how it should be done all day) kindly volunteered to co-drive blind driving for me. It was extremely funny hearing "ok that's good ... thump ... oops" 7 timesSo I'm going to blame Toby for my placing last, he's used to getting the blame for stuff
Toby said:I expect Ian will be along in a minute to say it was my fault he ran Stacey over with my car ;-)
The first few wraps of the rope weren't tight enough and the drum was just turning inside the rope. The hole you poke the rope into with a little grub screw to hold it while you tension the rope doesn't hold very well so I've drilled the hole right through (nearly went all the way through anyway) and have a few inches out the other side now being gripped by the rope as it goes on which has let me get some good tension on it.Jon Wildsmith said:Not sure what to think of my goldfish yet. On Saturday I needed to winch up a steep climb which should have been easy work for it but I ended up having to double rig it through a snatch block to get moving. On the single line pull, it sounded like the winch was doing some work but the truck wasn't moving![]()
