- May 20, 2010
Can someone point me in the direction of the form please? Thanks
Looking forward seeing what the Mog can do Ian
I was hoping to have an off road run before Lincomb so that I had an idea of what it will and will not do. Unfortunately time has got the better of me so its first off road trip, in my hands, will be at Lincomb. Fingers crossed it turns out to be half way decent.
Ian
Thanks, I am hoping that its lack of ATRAC and the fact I intend to avoid any flat, level grass areas should see me good
Thanks, I'll keep you in the speed dial, just in case.Crispin said:ok, if it's back and you do inadvertently find yourself on a glassy plain, you still have my number.
I was going to adopt the slow steady technique which will be quite a change for me. Since there is no power worth mentioning, I guess pick a line and let it plod through / over is the way to go?stumog said:does this mean I need to give you some pointers ?
