whilst on my laning trip to the lakes a few weeks ago, the front wheel bearing went very loose on me. so we stopped and tightened it up, which meant i was able to carry on and do all the lanes.
so i ordered new outer wheel bearings.
i then discovered that the landrover box spanner was too small by a few mm.
so i made one out of a piece of box section.
when i removed the free wheel hub on the passenger side i couldnt believe how much water came out.
i put it all back together but it still felt loose on the driver side, so i bought a new inner bearing aswel.
so hub off.
and tapped the old bearing race out.
old and new.
packed it full of plenty of grease.
refitted it.
the free wheel hubs were a bit dirty and corroded so i soaked them in de-greaser and scrubbed them with an old tooth brush.
they came up nice and clean.
i put it all back together and its a lot better but theres still some movement on the driver side. it looks and feels like the hub is loose on the swivel ball. is there away of tightening this up, or is the ball badly worn?
i decided that my little scaffold straight through exhaust must be restricting it as its felt very slow lately. i will be having a complete new system built soon in 2.5 or 3" stainless after the new engine goes in.
but for now i decided to knock something together.
so my scaffold straight through, compare to the original size bore.
so i cut the flange off the scaffold one, and welded it to an old exhaust section that i cut to size.
fitted.
after the last 2 trips ive been on, both times ive ended up winching where other trucks have driven, due to the other trucks having rear lockers, and me only having the original LSD. so with that i decided to bite the bullet and buy an ARB. i did want a KAM electric locker, but i could be waiting a long time for them to finish developing there toyota locker, so i chose an ARB.
so half shafts out.
and diff out.
hung it up to drain over night.
thats now been sent off to devon 4x4 who will be fitting the new locker and sending it back to me. hopefully in time for lincomb. they should be sending me the compressor, switch, solenoid, hose etc. today so i can get that all fitted over the weekend.
i will get a front one soon. i could have bought one now quite easily, but i just couldnt justify spending all that money in one go.
engine swap next, then X-ENG hand brake, stainless exhaust, then front locker then new wheels.
and some where in the middle of that i want to finsh my rock sliders and make my new rear bumper.
