Update time.........................
There were a few gaps between the 2mm steel and the arch where I had cut slightly too much out. It was too much to weld up and I was happy that it had been welded in enough places + bolted through the inner guard so will be strong enough.
I was going to use Tiger seal.
But it had gone off in the tubes.
So I bought some stikaflex.
I also sealed round the inside between the tube and the 2mm steel.
I did lots more filling.
I removed the handle off the rear door and found it full of Lincomb sand!
I removed the scuttle panel.
As I wanted to sand down and put more filler on below the windscreen as it had never been perfect since I did it in a rush just over a year ago.
That was LJ last weekend.
Work next..................................
I had to make some Suzuki bash guards.
I cut some alluminium on the guillotine.
Used the bandsaw next.
Marked them.
Bent them.
Cut the brace pieces.
I needed to use the Foronius welder to weld the braces on.
These are what ARB switched to a few years ago from MIG welders, as they can weld steel with virtually no splatter.
I set it up with the material thickness.
I had a practice on some scrap.
I started welding the braces on.
But it had penetrated through the other side badly.
So I did a bit more practicing after adjusting the machine.
And this time got virtually no penetration through the other side.
Got them all done.
These are the new Suzuki winch bumpers weve designed. The idea being to have bolt on ends as shipping on normal bumpers was ridiculously expensive due to the length.
The bench in my welding bay was completely unsuitable!
It wasnt big enough, the 3mm steel top was all buckled and distorted from being welded on and it was too low.
I explained this to my boss and he said I could build a new one.
My technical drawing.
Cut some 50mm box section that has a nice thick 5mm wall.
Started welding it all together.
2 frames built.
I needed to weld on the next pieces and as always with something like this distortion is an issue. As I wanted the pieces I was welding on to be square in both directions I had to constantly check them as I welded and work out where to weld next knowing that the metal would pull over towards the side being welded.
I then turned it over and welded it to the other frame.
I dragged the old bench out.
I could then move the new bench in to position.
As I designed it to have the foronius welder at one end, my tool box could now go against the back wall giving me more floor space and room in the welding bay and making it much easier to get to and use the foronious, which I'm hoping to set up for steel as I've heard such great things about them.
Ive order a piece of steel 10mm thick for the top. Should be ready Monday, I hate to think how heavy it will be at 2.5m x 900mm.
I also wanted to put a sheet of steel on the other bench.
So I cut a strip off the edge of a sheet of 3mm.
Next I wanted to add a shelf to the bottom of the new bench.
I cut some steel next to close off the gap between the shelf and the floor as often when you drop things they bounce under the bench if their left open.
Screwed it on.
The shelf I want to use for storing projects I'm currently working on.
I made some more guards.
We fitted some of the 25mm wider than standard 80 series flares that weve had made to my bosses 80.
They left a gap on the rear ones noticeable when the door(s) is open.
So I made cardboard templates and then made some alluminium strips to fill the gaps.
I then sent them to be powdercoated black.
I had a customers Jimny in that wasnt driving well and it was suspected the castor was out so I had to fit castor correction bushes.
I also changed the bosh on the chassis end to drop it down and forwards slightly.
And my last job of the week was assembling Sierra tube door kits to go with all the doors I built.
Back to LJ..........................
I filled over the now dry stikaflex.
I borrowed some wheels from work.
The idea being these would make it much easier to spray LJ, particularly the roof.
Had to use a piece of wood to get the jack back out as it wouldnt go low enough.
The seam sealer I used on the roof gutters 18 months ago hadnt worked very well.
Scraped the old stuff out.
The gutter needed straightening slightly in a few spots.
Gutters cleaned ready for rust killing.
I went and bought the paint this week. I was going to go for two pack but speaking to the very helpful lady in the paint shop she advised me not to for a few reasons but the main reason was how bad that stuff is for your health!
So I got some enamel.
My boss very kindly said I could borrow a gas heater for the weekend as its now the middle of winter and a bit cold for spraying cars really.
Lots more filling, sanding, filling, sanding and so on...........................
I found this tool useful for getting the filler nice and straight and flat.
I picked up some more stikaflex for the gutters.
Rust killed and ready for the stikaflex.
I wanted to re-fit the piece of glass in the passenger door to give me something to stick the masking tape to.
I cleaned the linkage up and gave it a grease up.
A little job that I wanted to do before the respray was to relocate the side repeater lower down the guard as it was behind where the snorkel sits.
I removed the plastic inserts that the side repeater screws into.
Out with the cardboard.
Step drills are perfect for thin sheet material as it doesnt grab and twist like a normal drill bit. We use them all the time when fitting snorkels.
Marked it.
With the side repeater in position I could drill through the mounting holes.
I could then open them up enough for the plastic inserts to fit.
I did lots more filling and sanding then got LJ outside.
I needed to clean the dust up.
Blew all the dust off LJ.
I dug my big tarp out which I havent used since leaving the UK.
And started building a makeshift spray booth.
Masking tape and newspapers next.
I then gave the whole truck a good wipe over with rags dipped in thinners to remove any dust, dirt or grease.
Almost ready for paint.
Set the heater up.
Mixed up the primer.
And gave it 4 coats.
On the pic below you can just about make out a dent on the bonnet. This is the only dent on the whole truck that I havent tried to fill. This dent happened in the accident and is a constant reminder for me whilst sat in the drivers seat what can happen when you become complacent and arnt concentrating!
Tomorrow I will sand the whole truck down with wet n dry paper and get the coats of enamel on.
