An Entrie Week Working On The Treehouse Project!
Last week was possibly the hardest working week I've ever done.
I'm pushing really hard to get the tree house completed before I leave Piranha, so last week I worked 6am to 8pm everyday and worked flat out to get as much done as possible.
When we first got to the farm on Monday morning we were checking the livestock.
When we discovered some of the sheep had escaped, so we lost the first hour trying to chase them back in, which I loved as I got to ride his 250cc dirt bike round.
Once that was done we could finally get back on with the tree house build.
So this was how we left it last time.
With the half finished roof.
My first job was to finish cladding the roof.
We got the tower setup on the side.
Insulated the wall.
And start cladding.
We fitted the window so we could clad around it.
The roof was by this point almost clad in tin sheets, but I had left the last couple of sheets off for access.
And that was the first day done.
The next day nice and early I climbed up onto the roof for the first really dangerous part. Shimming along the ridge on my bum with a leg each side to install the capping pieces. A fall from this height really wouldn't have ended well, so I had to be bloody careful.
The next job was to finish cladding the bell tower.
Alan cut me some tin sheets.
I pulled them up with a rope and got them screwed on.
And finished cladding this first side.
My work colleague Michael came up to help us for a couple of days and we cracked on with the next side.
Insulation first.
Next window went in.
A pic of the completed roof.
The next morning.
We cut off the excess.
*I should point out here that I should in hindsight have put this window much higher up the wall, but more on that later.
Insulation went in next.
This was the next really dangerous bit!
The only way to get up to clad this side was up a very steep ladder resting right to the edge of the platform.
Michael cut the boards to length and I fixed them in position.
The other side looked awesome now it was lit nicely in the sun!
Alan chainsawed a seat and drinks ledge into the stump.
Meanwhile Michael and I finished the other side.
Front next.
Insulation and windows fitted.
The next morning we finished off cladding the front.
This side was time consuming cutting around all the windows and door.
And lots more cuts around the roof trusses.
Front done!!
Timber for the veranda next.
Did some more notching on the pine posts.
Started fitting them.
Roof rafters next.
Fitting the veranda roof revealed a huge cock up that I had made.
The window on the gable end is far too low to allow the veranda roof to run all the way round at the same height we wanted the front to be at.
I'm really pissed that I didn't pick up on it sooner, as moving the window up before we did the cladding would have been easy. Missing this mistake on paper when I drew the plans up is OK, things like this often get overlooked, even by experienced architects, we used to come across problems like it all the time when I was building. But I should have picked up on it sooner.
My boss was cool about it though and isnt stressed at all!
So the roof would need dropping slightly on the side.
Tin sheets next.
I screwed all the sheets down and then got up on top of the roof and cut them to length with a 7" angle grinder cutting disc in a circular saw. Worked great!
Cut the rafters for the other side and beveled the bottom edges with the plane like I did on the main house roof.
The roof will have a slight step in it after the hip. Thankfully its on the least seen side and wont interfere with how the front looks.
This is where the firemans pole will be and the roof will have another little hip and roof section above the pole.
And that was as far as I got.
We need to go back and:
-Finish the veranda roof.
-Fit the firemans pole.
-Fit all the handrails around the deck/veranda.
-Build and fit the staircase up to the tree house.
-Finish off fitting out the inside with the OZ Pig, mezzanine floor with ladder and bed and architrave around the windows and door.
I'm really hoping I can get it finished before I leave.
The next 2 weeks I'm at Piranha finishing the trailer project, Solar Suzuki and doing some more on the airboat.
