- Oct 13, 2010
was out working on my truck by 7am today!
i do like how she sits on the wide 12.5" x 35" x 15" tyres and rims.
looks better than on my other set of wheels and tyres which are a bit narrower at 10.5" x 35" x 16".
did a bit more sanding.
painted the guard and recovery points.
bit more filling.
the reason the rear quarter got so badly damaged by the rear bumper, was because the bumper wasnt attached properly.
the 4 bolts holding the recovery point and bumper in place, were almost loose because the thread in the captive nuts had stripped.
so i want to make sure it doesnt happen again.
so to fit this in place i needed to get the backing plate in position, but it wouldnt fit in position due to 3 captive nuts on the bottom of the rear cross member getting in the way.
a lot of drilling, chiselling, and grinding later they were off.
backing plate needed a tiny amount grinding off the bottom.
it then fitted perfectly.
spotted 2 captive nuts at each end of the chassis cross member that i intend on making use of then i refit the bumper.
so with the recovery points 4 bolts, 2 other bolts underneath, and now another 2 bolts each end, that will mean the bumper will be held on by 10 bolts, so hopefully it wont move again, even when hitting rocks hard!
i then came in and got changed ready to go to the 4x4 show.
when we got there we were greeted with a carpark almost full of lamerovers!
but did spot a few nice 80's in the carpark!
had a look around, and spotted Mike Hatton's Isuzu. he had labeled every single mod on the truck in pen on the body work, which i found funny.
best of luck to Mike in the competition.
only spent about an hour there and by that point id seen everything!
defiantly less there than last year, and although ive said it before i shall say it again. im not going again!
if it wasnt for the fact it was 30mins from my house i doubt id have gone this year.
saw a few more cruisers on the way out.
so what did i buy..................................
well a tree strop from goodwinch.
id seen these in the back of a magazine and thought they looked good! no need for D shackles, simply put the strop around the tree and clip my big competition style winch hook through the triangles on the strop.
and my mate bought me a replacement wheel from silverline, to replace the one he destroyed when he failed to tighten all the wheel nuts.
while at the show i had a chat with Paul at westcoast off road centre. i asked him about castor correction bushes for my 70, and he said hed never fitted them to a 70. i told him the steering some times feels a bit vague and twitchy.
he then asked if id tightened up the steering box. i told him i hadnt and he explained that theres a 17mm nut on top of the steering box, undo the nut, and then turn the bolt in the centre with a screw driver, before then tightening the nut back up.
had a look when i got home.
there it is.
it was a bit of a pain to do, but i got there eventually.
drove to my mates to get the paintwork done and realised i must have tightened the box up too much, as the steering was very heavy.
so got some primer on.
he then tells me hes used the wrong primer, and this stuff wont have fully gone off for 4 hours!
so wont be able to top coat it today.
so i came home.
picked up 80 litres of fuel today. should keep my truck running for a few weeks.
fitted the steering guard and recovery points.
hoping to get the rear quarter painted soon as i want to refit the back bumper.
bit more filling.
there it is.
so i came home.
