ModelMakerMan
- Jun 25, 2011
Im surprised those calipers dont fit because they look exactly like the ones on my KZJ70 with vented discs.
Roger Fairclough said:Ben.
If you put a suitable spring on the shackle pin, it wont rattle at all.
Roger
Sam said:Ben... do you sleep?
ModelMakerMan said:Im surprised those calipers dont fit because they look exactly like the ones on my KZJ70 with vented discs.![]()
Sam said:Since my last post at the weekend I have managed to find just enough time to build two thirds of the first drawer!![]()
But then I did sleep for 8 hours on one of the nights so I can see where I'm losing the time!![]()
Keep up the good work though fella - it's an inspiration to us lesser mortals!![]()
The old pig tail recovery loop is much better suited to forces in different directions, especially as the shackle can rotate in line with the pulling force and not try to bend the loop. Obviously you can make your style of recovery point massive enough not to be the weak link - it will be interesting to see how they stand up to some heavy use, which I am sure you will subject them to!ben said:
What year and model is your KZJ7* ModelMakerMan and I'll look up to see if the discs and calipers from yours cross over to any other vehicles for BenModelMakerMan said:Im surprised those calipers dont fit because they look exactly like the ones on my KZJ70 with vented discs.![]()
sae70 said:What year and model is your KZJ7* ModelMakerMan and I'll look up to see if the discs and calipers from yours cross over to any other vehicles for BenModelMakerMan said:Im surprised those calipers dont fit because they look exactly like the ones on my KZJ70 with vented discs.![]()
edit - I've had a quick look at a 1993 VX hard top KZJ70RV-MEXW and ToyoDiy list a solid disc![]()
Part 43512?60100 (DISC, FRONT) was found on the following models:
Date range Model Frames/Options Found in diagram
01/1990-07/2001 TOYOTA LAND CRUISER BJ73,LJ7*,RJ7*,HZJ7*,PZJ7*,KZJ7* 43-03: FRONT AXLE HUB
Model Dates: Matching Models: Model Options: Links to diagrams:
05/1993-01/1994 BJ73LV-MPW VM, EUR, HT, LHD, 3B, DSL 43-03
05/1993-07/1999 HZJ70LV-MNW LX, EUR, HT, LHD, 1HZ, DSL 43-03?43-03
01/1990-04/1993 HZJ73LV-MNW LX, EUR, HT, LHD, 1HZ, DSL 43-03?43-03
05/1993-07/1999 HZJ75LP-MRW STD, EUR, PIC, LHD, 1HZ, DSL 43-03
05/1993-07/1999 HZJ75LV-MRW STD, EUR, HT, LHD, 1HZ, DSL 43-03
05/1993-03/1996 KZJ70L-MRXW STD, EUR, TP, LHD, 1KZT, DSL 43-03
05/1993-03/1996 KZJ70LV-MEXW VX, EUR, HT, LHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ70LV-MNXW LX, EUR, HT, LHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ70LV-MRXW STD, EUR, HT, LHD, 1KZT, DSL 43-03
05/1993-03/1996 KZJ70RV-MEXW VX, EUR, HT, RHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ70RV-MNXW LX, EUR, HT, RHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ73LV-MEXW VX, EUR, HT, LHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ73LV-MNXW LX, EUR, HT, LHD, 1KZT, DSL 43-03?43-03
05/1993-03/1996 KZJ77LV-MNXW LX, EUR, HT, LHD, 1KZT, DSL 43-03?43-03
01/1990-04/1993 LJ70LV-MEXW VX, EUR, HT, LHD, 2LT, DSL 43-03?43-03
05/1993-12/1994 LJ70LV-MNXW LX, EUR, HT, LHD, 2LT, DSL 43-03?43-03
05/1993-07/1994 LJ73LV-MNXW LX, EUR, HT, LHD, 2LT, DSL 43-03?43-03
05/1993-03/1996 RJ70LV-MNEW LX, EUR, HT, LHD, 22RE, EFI 43-03?43-03
05/1993-03/1996 RJ73LV-MNEW LX, EUR, HT, LHD, 22RE, EFI 43-03?43-03
