update time.
i messaged and called a few of the recommended sellers, and the place Trevor linked to. they all came back to me quickly, and the prices were all better than my local dealer.
need my truck back on the road, so decided to just buy the seal from my local dealer, as it meant i could get it today.
i wont be using them again though.
that one seal from my local main stealer, cost more than the 5 that arrived from milner today.
decided to get a rear panhard rod fitted, as i dont know how long it will take for super pro to find and send me the correct bushes.
i got the one end bolted on fine, but the other end wouldnt line up properly, as the panhard rod was twisted to the axle.
this is due to the axle having been rotated slightly, by the fitting of bigger springs.
it was a real struggle to get the bolt in. in the end i had to use a crowbar and big screwdriver to twist it enough to hammer the bolt in.
but at least its back on.
so to remedy this, im going to cut, shut and sleeve the panhard rod, to get rid of this twisting effect which is eating the bushes and creating the death wobble!
this is the rust coming through on the new metal i welded in last year.
need to get some dintrol ordered and sort it out.
jacked the front end up, so that hopefully all the oil would run to the back of the gear/transfer box.
so front prop unbolted and ratchet strapped to the box out of the way.
i found i couldnt stop the flange from turning when trying to undo the nut.
so found a piece of 40mm x 10mm steel in the shed and cut a 400mm piece off the end.
marked and centre punched where i wanted to drill the holes.
drilled them out to 10mm, then marked where the cut out needed to be.
did a few rough cuts with the grinder.
then cleaned it up with a grinding disc.
bolted it on.
undid the nut, and pulled the flange off.
old knackered seal.
seal out.
new seal in.
flange back on.
referred to the toyota workshop manual for the torque settings.
all done.
just need to top the box up with a bit more oil now.
