Roger Fairclough said:
If he cocked up his castor angle, I'll kill him.
Roger
right so the problem with the truck..........................
i know this probably sounds crazy but its almost like some one has tampered with my truck in the middle of the night while its been parked on my drive.
the reason i say this is because like ive said a few times now on the last few pages, the truck was driving perfectly and the death wobble had almost completely gone. i drove 60+ miles with my mate and the death wobble only appeared once for a few seconds and then vanished.
i then parked the truck up for a week and didnt drive it, i then fitted the X-brake calliper and cable and got that working, removed the front prop, fitted a new oil seal, and re-fitted the front prop, and changed the rear panhard rod.
so i then come to drive it and find the death wobble is worse than its ever been!
so i believed it must have been something id done/changed, because before it drove fine.
so with my mate turning the steering wheel slowly left to right, this is what i saw (apologies for the poor vid quality, was getting dark and i obviously wasnt holding the camera very still.
[youtube:34nmsxmn]yRmgQnRM5j8[/youtube:34nmsxmn]
so as can be seen in the vid, the whole bush is moving but not the actual bolt, which appears to stay still.
this is the end of the front panhard rod which has the problem.
came to unbolt it and found the bolts on both end wernt very tight. maybe theyve worked loose due to the extremely bad vibrations/shakes that ive been experiencing. but i am 100% certain they were tight after i fitted them. maybe some one loosened them in the night?
after removing the bolt and pulling the panhard rod down it became apparant that the new polybush doesnt look great.
after pushing the metal sleeve out, i found the polybush damaged underneath where the middle of the metal sleeve sits, not sure how this bit could get damaged.
anyway i tightened both ends up nice and tight. (even used a split pin Roger!
took it for a test drive and its still got very bad death wobble above about 35mph.
ive got another new bush i can fit, thats not the issue, the issue is why has this happened and how do i stop it destroying another new bush?
when first fitted it was fine, since then ive probably done 200miles at most.
the metal sleeve still feels tight inside the bush, and the bush still feels tight in the panhard rod, so im wondering whether fitting a slightly bigger bolt would help, because the bolt does have a tiny degree of movement inside the metal sleeve.
i did also wonder if the bolt hole(s) on the axle where the panahard rod mounts might have become enlarged slightly, so i could weld some thick washers on, but judging by what i see when the steering wheel is turned, ie. in the video, the bolt doesnt appear to move at all.
im confused and my head hurts after writing that essay.
time for a shower and a beer!
