decided to start fitting the front locker bits.
so the view of my dash.
so one spare switch space, ready and waiting for the front locker switch.
stereo and switch panel off, and i can start identifying the correct wires in the spaghetti of wires.
switch fitted.
checking they all illuminate with side light, and when the switches are switched on.
needed to fit the second solenoid and air hose to the compressor.
luckily i managed to find the compressor instructions.
had to remove the battery and then rotate the compressor forward to get the solenoid on.
all fitted and battery back in.
so the compressor is all ready for the second air hose to be connected.
so air hose all connected and clipped in place.
runs along the bulkhead with the other hose, but keeps going to behind the brake servo.
then drops down with all the brake hoses.
put some tape over the end to keep dirt out, and left quite a bit of slack on the hose for now, ready to connect up after the locker is fitted.
next i decided to sort the front panhard bushes out.
panhard rod off.
the bush on the axle end didnt look too healthy as it was indented from where the axle had been digging into it.
tapped the metal sleeves out.
then used a socket, and an off cut of box section and the vice to push the bushes out.
the bush from the chassis side (the one showing the movement in the video) was very badly damaged!
even the other side of it had started to split.
compared to a new one.
pressed the new ones in in the woodworking vice.
ready to bolt back in with the new bushes fitted.
decided to actually read and follow the FSM this time.
used a washer this time to prevent the new bush from getting damaged by the axle.
all done and torqued up properly. i tightened it the same as i did last time, so it felt tight, and then got the torque wrench on it, and it went about another turn.
no time to test drive it tonight, but im 99% certain this will have fixed it, will find out tomorrow on my way to work.
i just hope these bushes last a bit longer than the last ones.
