switches arrived from John this week.
decided to use the red switch for my glow plugs because there isnt a sticker for glow plugs.
decided to wire up my new solenoid and remote's for my winch today.
this is the box that contains the old solenoids.
once i unbolted the cover i saw quite how badly burnt out they were. but theyve had a lot of abuse over the past 3 years.
removed the old solenoids.
and wired up the new solenoids.
so back to the steering guard...........................
i marked where the holes needed to be.
and drilled them out.
the 2 bigger holes in the middle are 2 clear the bolt heads where my winch mounts.
i then bolted this in place on the truck.
needed to trim the guard down as it was a bit too wide.
so clamped a piece of wood onto the guard to act as a straight edge.
got it in place and used a ratchet strap and my winch to hold it in position.
decided it needed to be cut down a bit as it was too big and the steering bar would have caught.
got it back in position and used some pieces of wood to wedge it place.
once i was happy with the position and angle i tack welded it.
unbolted it and got it on the bench ready to fully weld it.
turned the amps right up on the welder and put a nice big seem of weld all the way along the joint.
found a suitable piece of 50mm x 5mm flat in the shed.
and cut 2 110mm pieces.
to get the length i needed these pieces to be i used a square.
welded them on.
cut 2 pieces of 50mm box section with the correct angle on.
put them in position and then welded every edge.
bolted the guard back onto the truck.
decided to use the high lift jack to lift the chassis up a bit and make sure the guard doesnt catch on the bar.
loads of room.
obviously the guard isnt going to provide much protection to the bar when the truck is fully articulated, but it should be ok in most situations.
had a quick look through the passenger wheel arch, to see if i could get to the fuel pump so i can up the fuelling, but it still looks very difficult to get to.
might wait till i remove the fuel pump, if i ever need to.
didnt start wiring up the electric fan as want to get a thermo switch fitted first really.
