- Oct 13, 2010
thanks.
i fitted the KZJ70 rad this afternoon.
it fitted perfectly, with just one vacuum hose being in the way.
fitted a new genuine 4-runner top rad hose as the top hose. i couldnt use the new genuine 4-runner bottom hose as it was at the wrong angle. so i used the original 4-runner top hose for now, as the bottom hose. plan is to use the new bottom hose that wouldnt fit, once i get the X-ENG thermoswitch housing which will sit in the bottom rad hose. should be able to make the new hose work, because i will turn it round slightly after cutting it in half.
cable tied the vacuum hose to the top of the rad.
got 10 litres of pre mixed coolant.
put 8.5 litres in the rad and the other 1.5 litre in the expansion bottle.
i think i need another few litres though, because a lot of coolant came out when i removed the water pump, so im guessing the engine must hold a good few litres.
anyway..............................she fired straight up, and didnt go bang!
actually sounds noticeably quieter, the only thing i can think of is that the old tensioner pulley did have a bit of play in it, so maybe changing that has improved things.
i ran it for half an hour and most of that time i had the blow heater on full. the engine got up to temp, but the bottom rad hose stayed cold, where as the top one got hot. so wondering whether ive got an air lock.
going to see if the rad needs topping up tomorrow, as id have thought if the stat opened then the level in the rad should have dropped.
re-fitted the back bumper now its been painted.
so next jobs/mods...........
fit electric fan and wire up to thermo switch.
plumb in the intercooler.
sleeve the rear steering bar, and then fit both new strengthened bars.
make steering guard.
make guard to protect the exhaust down pipe, transfer case and X-ENG hand brake.
wire up new winch solenoids, wireless remotes and new cut off switch.
either change the output bearings in the transfer case, or change the whole box.
once box has been sorted, re-fit X-ENG hand brake.
convert the rear brakes to disc.
fit front ARB locker.
