thanks for all your help guys.
regarding slipping a piece of solid bar inside the tube, that would be ok, but i wouldnt be able to weld it in place, as the track rod end goes quite away inside the tube, so i wouldnt be able to get into weld.
i could leave it loose though, if it was quite a tight fit?
will see if i can find anyhing tomorrow.
regarding having new bars made, i know for Glyn Lewis to start making the 80 series sumo bars he had to invest in 2 taps, to cut the threads in the ends of the bars. 1 is a right hand thread and 1 a left hand thread.
so if i was to have some made, i think id call him, as i know hes got the cutters and machines to make them.
but......................ive spent 2 grand on my truck in the last month, so really need to try and save some dosh and make more stuff myself.
so anyway.............back to the sleeving.
1 piece of galvanised tube.
the steering bar wasnt a bad fit inside.
i measured from the end of the slit in each end of the steering tube, and then knocked off 20mm to give me 10mm clearance each end.
tube cut to length.
marked the steering bar, where i intended to weld, so that i knew where to grind the tube in order to have nice clean metal to weld to.
all ready to weld, or so i thought.....................
then i thought damm................must put something inside the tube to prevent weld splatter from going on the threads.
a soaking wet rag poked down inside the tube would do nicely.
once id tacked one end with it horizontal in the vice, i could stand it upright in the other vice, and begin welding all the way around.
other end.
gave it a quick clean up with a flap wheel disc in the grinder.
so roughly assembled to make sure everything will work.
i just hope its strong enough.
need to give the welded ends a quick spray with some galv spray paint then thats the 1 bar done.
need a piece of tube for the rear bar next.
