i havnt been able to do much on my truck this week, due to the fact it has rained every single day! the joys of winter in the UK.
today started off dry and bright, so i decided i could get some done on my truck.
back bumper was in serious need of a paint, and was looking a little battered and rusty in places.
got it off and into the garage. then used a flap wheel disc in the grinder to clean off any rust.
then it was ready for a coat of red oxide paint on any bare metal.
next job was the rock sliders. id noticed that the rear supports on both sliders was catching on the sills slightly when the truck articulates off road, and the body flexes on its rubber mounts.
this had resulted in a small bit of rust, and an annoying creaking when off road.
so slider off.
and notched the sill using a grinder.
it then started raining AGAIN!
so i gave the rear bumper a coat of black paint.
onto the next sill/slider.
i then used a wire brush on the sill both sides around where id cut, and anywhere i could see rust. it then had a good coat of rust killer, and when that was dry i gave it a good coat of underseal and made sure i got loads on the sill where the front and rear skin join.
im going to pour a couple of litres of used engine oil in each sill, and in each chassis leg after i next do an oil change, because theres bits that i know i will have missed with the waxoil sprayer.
gave both sliders a good coat of black paint.
went to the scrap yard the other day, and while i was there i found and bought some intercooler pipes off a shogun that looked useful.
so i should have enough intercooler pipe, for when i connect mine up shortly.
if im not working next weekend i want to fit all my new engine bits, and new rad and then pipe up the intercooler.
once the intercooler's connected id like to up the boost and fuel pressure a bit.
