- Oct 13, 2010
Mark N said:what tire pressures you running? - looks like you could drop them on the slippy stuff?
tyres definetly needed dropping, but i hadnt got an accurate tyre gauge with me, so i didnt.
i dropped them down to 10psi at the last lincomb and it made a huge difference.
i want to get an ARB deflater.
Jon Wildsmith said:There was a thread about it somewhere I'm sure but I don't know what's available at the moment.Cossack said:Speaking of intelligent chargers Jon, what's a reasonable one to buy I think this may have been asked before
I think you will find 6 amp a bit under powered especially for dual batteries, 20amps or higher would be more like it IMO.Ben said:this is the one im thinking of buying.
http://www.ebay.co.uk/itm/330689827969? ... _993wt_698
thanks John, i will look for a more powerful one.
ModelMakerMan said:Some nice work there Ben, been following your front axle stuff closely as Ill be rebuilding both swivels on mine shortly after Lincomb (as well as doing the cam belt and injectors). Im on holiday in Florida (Lovely sunshine and 30*C! ) and Ive just received my trunnion bearing eliminator kit and a few other gooddies from Trail Gear to bring back with me.
Keep us posted on the battery/charging/alternator issue as I seem to have a similar issue ie: 2 fairly new batteries not holding charge/not charging properly from the alternator. Ive found that even with a sufficiently rated smart charger the batteries charge better separately and dissconnected from the vehicle.
thanks Dave.
id be interested to see some pics when you fit your trail gear bits.
after charging both batteries overnight, there both showing about 12 volts, but ive still got no power to anything, the ignition lights come on but there very faint.
my mate is coming shortly with his booster/charger so we can get it running then im going to take it to my local automotive place and get them to put there tester on it which should determine whether its the batteries, alternator or both at fault.
either way its going to cost me a few hundred pounds.
if its the alternator then it will be a mad rush to get to milners before they close at 12.30pm to pick up an alternator, so i can get it fitted and fixed ready for laning tomorrow.
if its batteries i might just buy some normal ones.
