When i got back i checked everything over and one thing i did notice, is that the diff was too hot to touch. Is this normal?
adrianr said:Hot diff. Are you 100% certain the ratios same front and rear?
Maverick said:When i got back i checked everything over and one thing i did notice, is that the diff was too hot to touch. Is this normal?
Stupid I know Ben, but you DID put oil in the Diff and Axle??
adrianr said:Did 100 motorway miles the other month then changed oils. Both diff just nice and warm, not hot
ModelMakerMan said:Yeah it does seem a little odd but thats just how its supposed to be done. Remember that you only tightened the bearing cap bolts by hand at this point so what is actually happening when you tighten the adjusting nut is you are pushing the bearing into the outer races which push against the nuts which pushes against the bearing caps which can move a little due to being a little loose. Remember the dial gauge is only measuring 10ths of mm.
username_11 said:i've read the entire thread nowvery nice cruiser
how have you found the kz on veg oil ? do you run 50:50 or have a heat exchanger
hot diff could be too little backlash. i aim for between 7 and 8 thou and take a reading of every other tooth lol
my lux diff has never got too hot to hold. same tyres, diffs and engine so fairly comparable
Graham said:Hi Ben,
I would be inclined to park the 'cruiser up.
Pull the diff out again, yeah, it's a pain in the asse, but really, some thing there is just not right.![]()
For the diff casing to get that warm, then who knows how hot the culprit is getting intside.
Might be an idea to put new oil in if you do decide to strip it open again.
Pull the axles, get the diff opened back up on the bench.
If you can hardly touch the diff housing, then I am sure you may find some "blue'ing" internally.
Before you get any metallic melting and pick up, I would have another good look, and check it is right.
Hope you find the problem.
Gra.
