WowJust spent an hour looking through those last two pages
It's always an inspiration true, but after looking at all the work Ben did repainting LJ, I'm looking and mine and thinking ... "It's not THAT bad! It can probably last another year. Or two." ;-)
Hi Ben. Did you use a face mask / respirator when you were spraying? I'm starting to plan my re-spray and would prefer 2K - will probably get a full face (maybe air fed) respirator. I once sprayed some items in a closed shed with 2K out of a rattle can and didn't use any respirator at all - not nice! My eyes stopped scratching and blurring after a couple of days, and my voice eventually came back after about 2 weeks. Lesson learnt.
What size compressor do you have? And what size nozzles did you use for the primer and top coats?
Hi Ben good job there must be sum job you can not do see you seen on the 19 tonytoyota![]()
Nicely done Ben, LJ is beginning to remind me of Triggers BroomI wondered if drilling through the magnets is what's made them less strong, those are usually very grippy as a rule. Won't be long now before Toyota sign you up for their Engineering team, top work mate.
