Lorin
- Mar 28, 2010
Checked all the fuel lines and pump connections for any sign of a fuel leak and there doesn't appear to be one - all hoses and connections are in pretty good condition. The pick-up filter in the tank was totally clear/clean and I replaced the main fuel filter again. Started it up and plumes of white smoke came out
I am not sure the injectors are a likely culprit as they were all reconditioned earlier this year.
I then rolled/pushed the truck to level ground and checked the oil which was full prior to Lincomb (250 miles ago), and it is now just under the half way mark. That's a lot of oil burnt in very few miles.
Even if it is only an oil or water seal on the turbo and the unit itself is okay my understanding is that there is no way of knowing anything without removing the turbo and inspecting it, unless I have the turbo pressure checked. Is this worth doing/does anyone even do this?
I know I could try Pugwash's suggestion and disconnect the water pipes but given that the truck is being prepared for a big trip I'd rather get to the bottom of the issue and sort it. I guess it is turbo off time
