Low speed - wrong gear??
Courtney Ffyshe Apr 9, 2018
  1. Courtney Ffyshe
    Courtney Ffyshe New Member I am in uk
    9
    0
    1
    Map
    Hi I've just bought a 2005 LC120 LC4 spec, one previous owner, 90k miles & full Toyota history. It runs fine except that when cold it seems to labour at low speeds (20-30mph) on a light throttle with a bit of rumble/vibration as though it was in the wrong gear - if I open up I can feel the auto box change down and it then goes fine. Should I be concerned or should I just stop 'babying' it?
  2. Animal Mother
    Animal Mother Well-Known Member Supporter I am in wales
    803
    287
    63
    Map
    They seem to relish being driven hard.
    Maybe check the air filter, stick some injector cleaner in it (proper stuff, not Redex), and then give it an Italian tune-up.
    Also, put 500ml of 2 stroke (mineral low ash) in for every full tank, both the car and you will appreciate it. Better running, quieter, smoother, etc.
    MAF and EGR probably need a clean too.
    Courtney Ffyshe likes this.
  3. TONYCY11
    TONYCY11 Well-Known Member I am in cyprus
    279
    100
    43
    Map
    The zinc in the 2 stroke oil will build up on the injector nozzles and affect the spray pattern and efficiency of the injectors and bhp will be lost . Maf sensor , and map filter cleaning , a clean air filter all very simple jobs but need the maf sensor cleaning spay as not to damage the sensitive parts, map filter can be cleaned by spraying carb cleaner then brake cleaner spay through till clean fluid comes through then blow through with clean air to get rid of any fluid, and a clean fuel filter , and egr clean will differently help . A full egr clean down through including inlet manifold is a full day job and very fidderly and messy if very dirty to say the least .
    StarCruiser and Courtney Ffyshe like this.
  4. moggy1968
    moggy1968 Well-Known Member
    2,275
    801
    113
    Map
    Change the oil and filter in the box as well. A lot of people only do the oil and a lot of auto box problems can be easily solved by changing the oil and filter
  5. Courtney Ffyshe
    9
    0
    1
    Map
    Thanks to all who replied - will report back!
  6. Courtney Ffyshe
    9
    0
    1
    Map
    OK I've put a dose of Miller's diesel stuff through it and given it a bit of stick. It runs fine ---except for a sort of reverberation/puttering at 1500 rpm in 4th (I assume - speed around 40mph) on a light/trailing throttle almost like a soft exhaust blow. Not present at any other speed and as soon as the throttle is opened a bit the 'box changes down and it disappears. If my radio had been working (which it isn't thanks to the boys at Halfrauds!!), I probably wouldn't have heard it at all!
    Any further thoughts please?
  7. Jack P
    Jack P Active Member I am in great_britain
    78
    19
    8
    Map
    Courtney Ffyshe and StarCruiser like this.
  8. foto2021
    foto2021 New Member I am in great_britain
    13
    0
    1
    Map
    Why not find a good independent Toyota specialist and have the car thoroughly serviced?
    We bought our 03 reg LC3 18+ months ago. It ran OK but with a couple of flat spots. A trip to our independent Toyota specialist for a full service, plus a gearbox flush and new filter, and the car drove like new.
    Some cars might survive and run well without proper, professional, regular servicing, but I don't happen to believe the LC120 is one of them.
  9. Courtney Ffyshe
    9
    0
    1
    Map
    OK many thanks for that! I am almost certain that the sound is caused by vibration and involves plastic/sheet metal rather than engine parts as described in that thread! It is extremely specific to 1400-1600 rpm so that points very clearly to the air inlet ducting/wheel arch interface as described.
    It's a silly niggle really because it drives very smoothly otherwise! I'll live with it until it goes in for some other bits & pieces in June.
    Thanks again to all - will report further then.
  10. lawrie
    lawrie New Member
    6
    0
    1
    Map
    Been using a 1/200 mix in my 2003 LC4 for 5 years. Now on 150k and purring nicely. There has been lots of research by Merc. and BMW and as long as you use basic mineral low ash oil it has been proved to be beneficial.
  11. TONYCY11
    279
    100
    43
    Map
    There are pros and cons the use of 2 stroke oil was first started been used in diesel engines when most of the sulfur was removed from diesel for pollution reasons ,the sulfur added to the lubricant of the fuel, and old non direct injection diesels benefited from using 2 stroke low ash mineral oil 1/200 , now euro diesel which is used in all EU nations has a lubricant added to the fuel that more than compensates what sulfur lubricant had . 2stroke oil although low ash is relatively high in zinc which is well known that it fouls the injector nozzles on direct injection diesels . Fuel additives that are added to help clean injectors could go someway towards cleaning the injectors , but I don't know if it will remove the zinc from the tips of the injectors which will affect the spray pattern , If you google ,( the facts of the use of 2 stroke oil in diesel engines) you will find a lot of info on the subject . I purchased 10 litres of low ash 2 stroke mineral cheap I paid £28 for it, as I too was planning to use it in my 120 lc, but after studying the facts I decided not to . I now just use it in my garden tools so its going to last me a hell of a long time before I use it up .
  12. Animal Mother
    803
    287
    63
    Map
    What about those vehicles that use a fuel injection system on a 2 stroke motor? Do they have special coatings on their injectors or something to prevent the buildup?
  13. TONYCY11
    279
    100
    43
    Map
    You can get full synthetic 2 stroke oil with zero zinc which is not cheap like mineral 2 stroke , mineral 2 stroke is for low tec 2 stroke engines like small generators and garden tools , don't know if semi syn is zinc free best check with the maker , the cost of making it zinc free might make it have no savings in price against full syn which is a superior product , and as far as I know not all fully syn 2 stroke oil is zinc free, only the top spec oil for ultra spec 2 stroke engines . which make it not viable to put it in a diesel engine . Also it is said fully syn 2 stroke oil does not mix well with diesel fuel so its a bit of a catch two situation . Only direct injection systems suffer from the zinc problem because the injector spay tip is in the combustion chamber , non direct injection dont get the zinc baking on the injector tips as they run at a much cooler temperature .
Share This Page
    Dismiss Notice
