David Killough
- May 6, 2011
I'm new to the diesel Cruisers, and recently obtained a 95 VX Cruiser with the 24v 1HD-FT turbo diesel. As most UK spec cruisers of that year are, it too is a manual. As I've learned, most Cruisers around the world are automatics, but Toyota apparently took a lorry gear box and put it into the UK spec Cruisers to help them sell. Not sure if that is fact or fiction, but maybe it will explain my problem.
I have a lot of trouble shifting into 1st and 2nd gear from the neutral position. Also, if I'm downshifting from 3rd gear into 2nd, it's quite a pain too. Sometimes I'm able to get in by double/triple clutching.
No manual gearbox in other vehicles I've driven did this unless there was some sort of problem, but I've heard that this may be normal.
Any ideas???
David
Any ideas???
David
