OK to put this to bed.
The workshop manual for the 80 states:
'When performing low-speed type brake tester measurements,
observe the following instructions.
(1) Put the center differential in FREE position.
• Shift the transfer select lever to H position.
• Turn the center differential lock switch to OFF and
check that the center differential lock indicator light
goes off.
(2) Shift the transmission shift lever to N range.
(3) Idle the engine, operate the brake booster and perform
the test.'
There is also a graphic showing the front wheels rotating whilst the rear are stationary.
regards
Dave
goes off.
the test.'
regards
Dave
