Andrew Prince said:
Sorry, Brett, your link just leads to the LCCSA site so not sure what requirements or rules you might be trying to point out. I know that you have to provide some info on your truck etc to register on LCCSA but as per my previous post, I am not aware of them requiring you to introduce yourself on the forum before you can register (how could you post that intro if that was the case?)
Strange, the link I posted should take you to the registration page, it does for me? I'm afraid I didn't pick up on the bit about an introduction Andrew
, so my posts were/are specific to supplying some detail about the user & their truck.
This is a segment of what the text says, (copied from LCCSA website) I hope this is ok to post?
LCCSA Registration Agreement
PLEASE read the information below very carefully, especially the section on the 'user name' convention. At the LCCSA your username is your name, in the format "Firstname Lastname" e.g. "John Doe".
This means that you also need to comply with the uppercase/lowercase convention, i.e. John Doe.
Exceptions to the format "Firstname Lastname" e.g. "John Doe" is applicable if the same name already exists. In that case, you are permitted to register with "Lastname Firstname" or "Firstname (Initial) Lastname" or "Firstname (number) Lastname".
Please ensure you enter your username precisely in this format as well as follow the upper/lower case convention or your registration will not be successful.
You are also required to enter all other relevant details, in particular your location and contact details.
