Just wanted to get some opinions on some of the non standard pros and cons for fitting a bigger suspention lift. I get all standard ones discussed in alot of forums but recently i have been torn between keeping my 105 at 4" lift or to lower it down to 3" ( I cant go much lower than that without having to change arms and shocks) i decided to lower it and actually lost 60mm front and 50mm rear which was odd because i went from medium rate coils to heavy duty so wasnt expecting as much sag. I immediately noticed the obcious on road benefits of reducing the height, but ive had some negative effects off road that arent generally discussed when talking about lift that i have noticed.
First things i noticed off road is my departure and approach angles were massively reduced not just small amounts by just dropping 60mm im now dragging my ass on some of my local tracks i glided over previously. The other one i didnt take into account was sill height, i got stuck in a watery rut and for the first time in this area had water ingress in the cab i feel this can be another area usually overlook when lifting and not bought up as much as a pro for larger lifts.
And im not sure why but when people generally talk about lift they say you have a higher centre of gravity and more chance of roll over and i definitely felt that on road cornering at speed but on the steep off camber accents and descents on a few local tracks i felt much less stable as i did with the larger coils and higher centre of gravity i also have a substantial amount of weight on the roof so it was confusing for me and dissapointing as centre of gravity was the leading factor for me to reduce the coils.
If anyone could elaborate on why thst would be great, could just be me getting used to the new setup but definitely didn't like the ride off road from 3" compared to the 4" setup another thing i did consider is that i kept the larger shocks in but have gone down 60mm so i have lost thst much up travel also
Cheers for any advice
