It does. I guess the battery is something to do with it being a clone rather than an original.frank rabbets said:I assume the proper Toyota key you have works? Therefore it has a transponder in it but no battery. I thought a transponder did not needa battery
Thanks Rob, I'll have a look.Rob said:The siren on mine is in the passenger wing, remove the indicator and you should be able to see it.
My flashing light is the same as yours. I didn't think fobs were still available but I'll check with my local dealer and see what they say.Towpack said:I have a warning light on the lower dash but this is for the alarm:-
The sounder is in the nearside front wing. Mine had been unplugged after the previous owner's dog ate his last alarm fob. I priced new fob's up at £60 each but at the time the dealer had an offer on of a new alarm ECU + 2 fobs for £160 fitted so that's the way I went/
Thanks for all the help folks
