SimonD
- Mar 15, 2010
Used condition and in good working order. These guys explain the setup better than I can:
I think the guy who removed it may have cut the wires to the front battery so I'm throwing the cables in but you may need new cables for the long run depending on where you put it. Also throwing in the set of cables we had running via an Anderson plus to a terminal block. No battery inside.
IRO £150 and it will need to be pick up in London but I'm happy to relay it through other members.
In addition I am going to near Worcester and then onto Leicester this weekend [4-5 August] so could possibly drop it off as long as the detour is not large.
