My keys don't look like that. No buttons, no fobsMy 1996 90 series has a fob on key chain and my 2001 90 series has buttons on the key itself as original I believe
You sent this to me. Mine is a UK spec, imported here to the US. I haven't tried this, but sent to my mechanics months ago. I'll try again soon. Do you think I should just try it with my master key?Central locking is standard on all 90 series I thought ?
Both mine are UK spec so i guess different countries might have got different keys , but if you can find t there is on the forum somewhere instructions on how to reprogram a new or used fob to your trucks security system . Something to do with turning the lock 6 times this way and 4 times that if I recall but maybe not because it was posted years ago .
Never had a fob, just keysI would assume it only works with a genuine Toyota fob ?
Are you talking about loosening here? I know there are other places, just using this as illustration.Hey there, I am new to the Toyota world and this forum.
I know on a basic level diesels have a hard time working air out of their systems. If fuel isn't getting to the injectors, I would try cracking the hard lines loose at the injectors then cranking the engine. It'll be a bit messy if you get them to spray fuel out, but if they do then you know that fuel has made its way there. Re-tighten the lines and see if that will get it going.
We had a non-turbo diesel tug at my last shop that would get air into the common rail if it sat more than a day and this is how we got it running. Hope that helps, and hope you get it back on the road soon.
Indeed, that is what the mechanics have said in the past... Trying to do too many things at the same time. Sometimes, I forget what I've reported here! Thanks Shayne.Loosening those very pipes is how you tell fuel is not getting to injectors which is something you stated earlier in the thread i think ?
I think it's electric too, and I'm tired of trying to figure it out, and tired of spending money on it. I'm probably just going to sell it as is and see what I can recover from it.The mechanics of it are really quite simple so in my mind its either the fuel pump is buggered which has never been heard of , or its an electronic issue and I'm reasonably confident all 90 series came equipped with an immobilizer which I must assume works by shutting fuel off .
I hate electrickery but if I were you I'd start researching 90 series TVSS .
Do you really think a new key/transponder rodeo is all it would take?![]()
Genuine Prado RZJ90 KZJ95 1KZ TE 3RZ FE Transponder Master Key Blank Uncoded | eBay
Find many great new & used options and get the best deals for Genuine Prado RZJ90 KZJ95 1KZ TE 3RZ FE Transponder Master Key Blank Uncoded at the best online prices at eBay! Free shipping for many products!www.ebay.ca
