roy.worley
- Jan 6, 2025
Hi all.
Does anyone know what the plugged off section was originally intended for?
Back of motor 2h, driver side, in the casting that oil cooler and filter are fitted to. In mine the oil pressure gauge screws into it and it continues maybe 50mm downward and is blocked off with a hex nut.
That sounds complicated, might have to add a pic when I get home.
Thanks Roy.
Thanks Roy.
