Rodger
- Mar 6, 2010
First a few basic facts: I am a complete dummy regarding electrics.
Our 40 series has HJ60 running gear - all 24v.
It retains the original 40 series wiring loom.
The alternator is a standard 40 series with an external regulator with three wires (+one that goes nowhere).
Over the years we have gone through numerous v/regulators but now, when I last checked, Toyota have only 1 left, so I must address the ongoing problem of over charging.
The set up we have now has a 24v truck voltmeter built in and I have tried to adjust the VR and use the headlights to control the charge and attempt to keep it below 28 on the gauge. This means I constantly have my headlights on and the charge rate is controllable because I giving it sufficient discharge(?). Without using the h/lights the voltmeter acts like a rev counter as the revs increase it goes straight into the red.
For years the 12v take off was from one battery but last year we fitted a dropper and took out that 12v feed converting the second fuse box (another original 40 series one) back to 24v. The dropper works from the cig lighter, has a switch and runs the CB and GPS which we only use off road to get L&L positioning as we are both map freaks. That all works fine.
When Blown80 visited the UK in 2013 he brought a modern replacement set up but it needs a 6 wire set up as per the 60 series and obviously my loom wasn't set up for that.
I have no idea how to address the problem and if you can suggest a solution then please put it in simple terms for me. Thank you
Rodger
Rodger
