What's in the box on the rh's? Lol!
Cool tyre haul there Shayne!![]()
Moral of the story- for me anyway is to check what the manufacturers say is the speed rating not the seller.
I’d give the pedders kit a try.
Why not use the bushes, as long as they are rubber instead of poly i don’t see much problems.
I have them on the shelf here and going to try them.
Many years ago I rang slee and simple ordered with card. There helpfull enough, he did seem to struggle with my accent. I didnt think I had one..Well i ended up with 35's which actually measure 34" while mounted on a 15x10 rim and her indoors seems to think its her kitchen so i best order some suspension .
I wanted the Slee 4" simply because its a job lot all you need kit but emails get an auto response because they are rebuilding their website , and time dictates i should look closer to home so how about these
http://www.euro4x4parts.com/parts/u...te_5_euro4x4parts_CASTOR-5-TOY-80-ET-105.html
Coupled with this
http://www.pedders.co.uk/4-inch-lif...ser-80-series-abs-fitted-models_p24719388.htm
Do i just not use the offset bushes included ?
I would post a pics of the wheels but windows has recently decided i'm not allowed to see my own pics and so hides them as soon as i upload them ?
Hmmm....Many years ago I rang slee and simple ordered with card. There helpfull enough, he did seem to struggle with my accent. I didnt think I had one..![]()
It was nigh on ten years ago and only a $80 part so cant remember the ins and outs. I can tell you for sure though that from this end i can ship 30kg for 130 quid, normally about five days.Did you wait long ?
how bad did import duties and shipping hurt ?
I've not had good experience with Pedders bushes my first set failed their first MOT after fitting - but that could be because i had so called professionals fit the suspension for me, i've only been in South Wales 17 years so i haven't found a good garage yet
Besides i feel the offset bushes are a needs must solution sacrificing the thickness of how much rubber is needed to allow flex for longevity , so if the drop plates are a permanent solution that can't wear out why not do it once .
Is there anything else i might need suspension wise ?
Lol. Im just the same. I actually used a mates card and gave him the money..I don't own a credit card , never have , i would probably pay by instant bank transfer but i don't think i've done that to America before and whether i like it or not i do live in the EUSSR so i guess that won't be easy either .
Didn't they make a whole in the Berlin wall one time![]()
I have a pair of drop boxes that lower the rear end of the suspension arm where it meets the chassis, you can have them FOC Shayne, if they’re any use to you.
I’ve clearly not spent enough time on this…
I needed new boots and like the Cooper STTs but they’re not made any more so it’s S/T Maxx or STT Pro. After reading this thread https://expeditionportal.com/forum/threads/stt-pro-or-st-maxx.164238/
I decided it was 50/50 between the two so looked them up and found the STT Pro to be only K rated (110Km/h) so off to my local Tyre shop I went to order the S/T Maxx as they are Q rated at 99mph. After 10 minutes looking none of his suppliers across Europe could supply the Maxx in 285/75/R16 but all could do the STT Pro which they stated as Q rated. Turns out thecrating on the Cooper website does indeed say Q but it varies between Q and K through the size range. Strangely I and he couldn’t find any Tyre rating chart that showed K rating.
So, 4 off STT Pro are on their way.
I’ve now entered the dead zone, where it all goes pear shaped.
Here goes. I’ve now been told I can’t have the Cooper STT Pro in Q rating because they have been downgraded to a K rating because of noise regulations. (What!) The exact same Tyre that came out of the mould now has to be rated slower (K) to make less noise on the road. S/T Maxx aren’t available in Europe because they aren’t ‘E’ rated, which is why I cannot get hold of them.
