Really?
Its the straightest Hi Lux iv ever seen, Most that look like they have been hit with a loading shovel Bucket Fetch 5 Grand........ Its got 100% MOT record
This is my current favourite. Mines a 3litre does that mean it's worth 60k?
This above Landcruiser, I don’t understand why it’s so highly priced, small engine, only 2 seater, just good enough for small things maybe shopping… can’t have roof top tent or carry big luggage in the farms, which other LCs do
For 39K one can get a 2017 RX450H n it serves all city purposes, bigger engine, refinement etc
The MoT history for this £15k cherished one lady owner FSH minter near me made me laugh.
This vehicle's MOT has expired You can be fined up to £1000 for driving without a valid MOT
This vehicle may be MOT exempt, for more information refer to MOT exemption guidance
YB02HVYTOYOTA LAND CRUISER​
ColourSilver​
Fuel typeDiesel​
Date registered12 July 2002​
MOT expired on28 May 2021​
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested20 September 2021​
FAIL​
View test certificate
Mileage154,215 miles​
MOT test number1350 2555 0116​
Test location​
Repair immediately (major defects):​
  • Nearside Rear Anti-roll bar ball joint excessively worn (5.3.4 (a) (i))
  • Offside Rear Inner Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting wheel arch holed and corroded (6.2.2 (d) (i))
  • Nearside Outer Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting sill area corroded and holed (6.2.2 (d) (i))
  • Nearside Inner Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting sill area holed and corroded (6.2.2 (d) (i))
  • Nearside Rear Lower Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting quarter panel corroded and holed (6.2.2 (d) (i))
  • Offside Rear Lower Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting quarter panel holed and corroded (6.2.2 (d) (i))
  • Nearside Rear Inner Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting wheel arch holed and corroded (6.2.2 (d) (i))
  • Offside Outer Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting sill area holed and corroded (6.2.2 (d) (i))
  • Offside Front Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting body mount corroded away (6.2.2 (d) (i))
  • Nearside Front Upper Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
  • Offside Front Upper Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
Repair as soon as possible (minor defects):​
  • Front Windscreen wiper blade defective both wiper blades (3.4 (b) (i))
Monitor and repair if necessary (advisories):​
  • Rear rear bumper missing sharp edges on show Dangerous
  • Rear rear seatbelts not tested seat in folded position
  • Tyre slightly damaged/cracking or perishing all tyres have minor cracking (5.2.3 (d) (ii))
  • Nearside Front Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
  • Offside Front Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Expiry date28 May 2021​
  • Nearside Front Outer Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
  • Offside Front Outer Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
  • Front Tyre slightly damaged/cracking or perishing on inner edges (5.2.3 (d) (ii))
  • Rear Vehicle structure is deformed but structural rigidity is not significantly reduced near tow bar mounts (6.1.1 (a) (i))
  • Rear Towbar slightly corroded within 30cm of towbar mounting (6.1.6 (i) (i))
  • Rear Coil spring corroded (5.3.1 (b) (i))
  • Nearside Front Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Offside Front Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Nearside Rear Brake hose slightly deteriorated (1.1.12 (b) (ii))
  • Offside Rear Brake hose slightly deteriorated (1.1.12 (b) (ii))
  • Nearside Rear Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
  • Offside Rear Anti-roll bar pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Bang on there Jacob, Say's it all really, Thats what your up against Folks when Buying a used 4x4.... Especially off the Second hand Dealers..... The List isnt that Bad 'tho' For a 20 year Old Landcruiser :lol:
Oh - just checked their site:
Our quality used cars are fully inspected, sold with a full MOT and serviced if required.​
We can also supply 3, 6 or 12 month warranties.​
If you are looking for great prices on quality used cars in the Scunthorpe area, then look no further. Roxby Road Garage offers a selection of high quality second-hand vehicles. Every vehicle we buy is thoroughly inspected by our highly qualified staff in our own workshops before being sold with a FULL MOT.
We are also more than happy to fully service your new purchase should you wish prior to collection and provide you on-going servicing, MOTs, tyres etc. whenever needed.
Someone knocked on the door to ask if I am interested to sell my LC. My wife opened the door and told him no he won’t sell it. That gentleman was looking at the car and told her these cars are no longer produced here n rare. My car is just a normal SUV with no modifications, what will he say if he actually saw any of other members fully prepared cars??
Once another gentleman came to give a quote for my driveway and he too told that this car is best for him to tow construction loads n asked what’s my price.
In few decades all fake cars will be gone and probably only our LCs and our car clubs will be active :)
