Rear Air Con
frank rabbets
I have the 2004 model with rear aircon controls in the rear roof lining. Is this supplied by cold air from the front evaporator via vents; or is there a rear evaporator. There are pipes running to the rear but have been told by the dealer that these are fitted if rear cold air box is required.
Frank
There should be a rear evaporator behind the driver side internal plastic wheel arch cover.
The rear is activated by a switch on the front dash as you knows and can/should run independant of the front.
Thanks Warren. Yes it's there. Much further back than I thought.
Frank
