PETE BELL
help im doing the brakes on the rear of my 90 off road car, i have removed the load sensing valve totally, there are two brake pipes that come from the master cylinder to the LSV i have cut the pipes and when the brake pedal is pressed gently fluid came from one pipe so i used it as supply and left other pipe to the side, when checking pipe work etc for leaks got brake pedal pressed more firmly found fluid came from other supply pipe. Should i blank off 2nd pipe or tee it into system??
i dont know why there are 2 pipes when from the LSV to the axle there is only 1 pipe. Cheers.
