warrenpfo
- Jul 21, 2010
I have made good use of my OEM jack that comes with the landcruiser and have found it quite useful. I think they are called a screw jack but am not 100% sure. It has started to show signs of coming to the end of its life as im not sure it is designed to be used day in day out and the "screw" bit at the bottom is not so smooth and showing signs of play so want to replace it.
Does anyone know of a good jack that will store in the same place as the OEM jack and retain its lifting strength and height. If i Google bottle jack all i get is hydraulic jacks and when i Google screw jack all i get is scissor jacks or old vintage screw jacks.
Thanks in advance
Thanks in advance
