- Jul 24, 2015
Hi Guys,
I need to alter the roof rack to allow for a Hannibal family roof tent to be installed.
Its a Front Runner expedition 2.3m roof rack with welded side rails at the front. However to allow for the tent to open I need to grind of part of the rail as per the photo below. This will weaken the roof rack slightly, however bearing in mind I will then bolt on a stiff piece of 18mm marine ply as per the base of the roof tent this will add back in significant stiffening and therefore I personally don't see the removal of the rails as problem.
Just wondered if anyone has any thoughts on this, or if you think it'll be a problem?
Thanks in advance
N
Thanks in advance
N
