Water also gets in through the rear lights.
Cheers! They are Accelera Badac Xtreme 35x10.5x16. They were so cheap I grabbed a set. Horribly noisy on the road though!Looks good whats the new tyres?
just go for 44" and be done : )That’s good to know. Yes I’ve got a 1” body lift. I am basically just removing the lip on the back arches with a little extra profile at the rear to stop the rubbing you can see below. Fronts are being cut 1” and the arch profiled again to address minor rubbing at full stuff. Will help if I want to run a little offset. I also want the option to run 38s just in case a set came up at the right price…..
