Hi everyone,
I could really use some advice. I’m currently in the process of replacing the cylinder head on my KZJ70 with a non-OEM head. Upon opening the engine, I discovered that this isn’t the first time it’s been worked on—the head that cracked wasn’t the original one either.
The engine is the original 1KZ-TE, with 300k km, maintenance every 10k but the previous owner seems to have tried to push some extra power on it.
Along with the replacement, I’m also having the engine block resurfaced to ensure the head gasket seals properly and prevent any future leaks. I’m committed to getting the job done right, but some people have been warning me that, because the engine has already been opened before, I’m likely to encounter more problems down the road.
I’m relatively new to 4x4s, and this is my first one. I really love this model, but I’m starting to wonder if I’m setting myself up for ongoing headaches with this engine. If replacing the head compromises the reliability of this otherwise well-regarded engine, I’d rather cut my losses now and look for another model or 4x4.
The truth is, I paid a lot for this KZJ70, and in hindsight, I might not have made the wisest decision with this purchase. But here I am, trying to make the best of the situation.
So, my main question is: Does replacing the head (especially with a non-original part) significantly reduce the reliability of this engine? Or should I keep going with the repairs and stick with it? I’d really appreciate any advice from those with more experience!
Thanks in advance for any guidance!
