scottmk1
- Jun 26, 2019
Ok so not long after I got the truck I decided to change the speedo face to one from Lockwood, so that it had an MPH scale on there. Fairly easy to do, the hardest part is getting the needle off as it's pretty tight. As you can see the black isn't a good match, but that isn't too important.
The next job was to do some sound deadening as it was very noisy in the cab especially at higher speeds. I used 2mm stuff from Silent Coat as the first layer, then some 10mm closed cell foam on top of that from the same people. Whipped the interior out, cleaned it up, and started applying the deadening.
I don't have any photo's of the finished article unfortunately, but it made quite a difference to the noise levels inside. A job well worth doing.
