SeaJays 80
it did need some surgery to clip back the exposed bone, hurt when I did it, and after the local wore off after the opp, hope its ok enough to return to work in a week
OMG - Shocking.!!
Feeling your pain & hurt, so sorry you had to go through this.
May you heal fast and without much hardship :cry:
Best wishes
that looks sore.
both the carpenter lads i sometimes work with have the exact same injury.
circular saw though, not 80 series diff..
does it fit in the stock shroud?
does it sound like concord taking off?
this arrived today, seems good quality, installing it this weekend
20-30 degrees is seriously impressive! I take it your old fan clutch was shot...?
I had re-oiled it over 5 years ago, but the temps were getting too high again even tho you could still feel resistance when trying to spin the fan
projects for the next few weekends, ARB locker for the front, and low coolant alarm
added a Walbro lift pump, it did show up a slight leak in the primer pump so have a new on on order, IP runs quieter, and car seems to drive smoother
she is in getting a full injection pump remove, rebuild, install...
