seeking advice on a 105 series lift kit
Dylan Baryla
australia
was looking at this to replace my current 2-inch lift and will go to 3-inch. has anyone had any experience with this specific kit or these Dobinsons shocks, currently am running Koni shocks and King coils with everything else being standard, such as sway bar links, radius arms, etc. Any advice or guidance will be greatly appreciated.
Toyota Landcruiser 105 Series (04/1998 to 11/2007) - Dobinsons Monotube Remote Reservoir Nonadjustable (MRR) Lift Kit 2" - [Leaving Land Cruiser Club]
If you go to a 3 inch lift then caster correction and probably adjustable panhard rods are a definite.... also probably adjustable rear links to correct the drive shaft angle.... and if you want to maintain flex sway bar links
You will have to do caster correction or it will drive awfully ...
