That problem has been there for a couple of months now. Here's what I've done about it so far:
- Brake test. Showed some problems that I fixed. No stuck pins or calipers now and all new pads. Did another brake test after that and everything was green, i.e. there was no significant difference between the braking force applied to each pair of wheels.
- Changed lower wishbone bushings. These looked bad. The problem got somewhat worse after that.
- Changed upper and lower balljoints (their time had come anyways). No change after that.
- Changed rear axle arms bushes (these had gone bad too). The problem got somewhat worse after that.
- Tried rotating tires. No effect.
So I pretty much cannot think of anything else to check up now and I cannot get rid of this problem. Can any of you guys think of something else I could do?
