So - what has gone wrong on your 120??
Jon Wildsmith said:
[quote="Gary Stockton":1ebeecyr]And the magnetic clutch is knackered again!!
They must be putting the wrong shim(s) on it, ask them what size shim(s) they needed for it ;) the wrong size shim(s) will stress the bearing in a direction it's not designed for when the clutch is engaged.
EDIT: shim = 'magnetic clutch washers' in Toyota speak.[/quote:1ebeecyr]
Yes i was going to say perhaps poor workman ship on the replacement items?
Joe
I have a 2007 120
Rims replaced under warranty
Wiper arms replaced under warranty
Injectors under warranty
Had to do one wheel bearing myself,but mind you, there is 460,000 kms on it!!!
Bloody hell - are you in Low Earth Orbit most of the time??? That's a long way in just 4 years! Give Graham a run for his money :lol:
What's gone wrong with my 120 ...
Slight 'bump from behind' - propshaft needed greasing (and when a hint of it started coming back, Toyota fitted a new propshaft).
Injectors were getting a bit noisy - changed under warranty
That's it. 4.5 years old now.
Trevor said:
Front calipers
Aircon relay
Water pump
Batteries
Changed injector washers as a preventative measure and a few self inflicted bits
I also forgot the 2 front wheel bearings replaced just after I bought it.
