Supermarket rust remover
Shayne
Good shout Shayne, a lot of lads use the same stuff on the downpipes on their motorbikes.
Wondering how to get the Krown coating off is what led me to it , so from my point of view its just a cheap heavy duty degreaser for the undercarriage .
I'd expect quick flash rust after using it which should give Aquasteel rust converter coating a good bond .
get the Krown
If you have Krown why would you want to remove it? Won’t it protect your metal? When I went for Krown this year, he told previous Krown penetrated rust and he removed all flaking old rust before spraying new coat.
I assume Krown will penetrate rust layer and protect metal below rust surface
I like the Krown Raj its definitely protected my truck for maybe 5 years without touch up .
Can't put anything over it though .
Plan is to remove the Krown and make everything black with Aquasteel just because it looks good .
Unimportant vanity really but then my sidestep is 2ft high so the underside of the truck is quite exposed and visible .
Its easy to imagine i will revisit Krown for treatment to protect the blackened finish .
  • Like
Reactions: Raj
