I jacked up both front wheels while playing around with the switch and turning by hand I can only get them to spin in opposite directions . Could be normal and maybe its not .
Thought i posted in the 80 series section but obviously not and you guessed correctly Bob .
Think i'm looking at it here at 25.15
53 minutes he removes the viscous and as far as I can tell the only thing thats likely gonna have me swearing is removing the snap ring circlip .
had one of those that you can swap heads for different clips and every time i put it down it fell to bits so i binned it . Suppose it wouldn't be difficult to make a set for a job I will only do once
yeah, got a set of those, wouldnt do it, got another set for the circlip on the end of the cv, that is the right sort but the one i have just wouldnt fit into the tranny case so had to buy some smaller ones.
Good luck anyway.
Been trying to use filler and paint all week but if anything the air is damper when it stops raining so at least this is a job i can do regardless of weather
