Once you have successfully connected to the car you should get a list of all the Ecus. Provided there are. O ecu faults the various modules should be highlighted in yellow. If not there is a connectivity issue. Click on the ecu you wish to aquire data from and then either read data or perform live tests. Im not a 100series owner but that's how it shows on other cars.
