- Mar 11, 2014
Drawback from full extent today took 8 seconds!
Thanks Bob. Hmm, I think that’s quite a bit quicker than mine. Might just be a design difference, but I haven’t changed the fluid since I got it, and I’m not sure what viscosity the initial fill was. I bought it from an agricultural machinery place more used to heavy gear, so perhaps they filled it with a thicker grade than it needs. The only info I can find just states hydraulic fluid, no spec. so perhaps a refill with a light grade would speed it up a bit.
Edit: I've just managed to track down the spec and it's supposed to use HLP46, which I think is a pretty common grade for tractor hydraulics, so that’s that theory probably out of the window. Might try a change, but it looks like it’s just slow !
One job I must do is get on with is an overhaul on my Stihl 80AV before winter sets in, it still pulls a 24” bar ok, but it’s getting on a bit and needs a good looking over. I must admit that I find it a bit heavy these days and treated myself to a smaller Husqvarna last year, a bit plasticky but zips through the smaller stuff. Mainly Ash and Sycamore to come down, but some big Spruce too. I had one of the Spruces down last year as it was too close to the house and beginning to look a bit tired. Luckily it was a clear path to drop it into a field behind the house, just had to take a bit of fencing down, still a bit of a nail biter, but all went well. 40” diameter at the base and the ground shook when it hit the deck !
