Beastrider
- May 31, 2021
After a couple of weeks of inactivity, my truck didn’t start this morning. The engine turned over slowly, dash lights dimmed etc. , so batteries likely to have discharged. I had to leave for work so haven’t checked voltage with multimeter yet.
It has a standard twin battery set up (KZJ95) and realise that I am unsure how to jump start or how to attach a charger. Should I connect jumper cables to just one battery and disconnect the other? If so, which battery should be jumped? Similarly, should I attach a charger to just one battery or should I charge the batteries separately off the truck?
Lastly, if I get the batteries checked at the local motor factor, I assume they would need to disconnect one of them and check them separately - is that correct? Thank you
