I was having a little poke about under my new 80 today as I had noticed an occasional 'tink' or 'clink' noise when changing gear/getting on the throttle at times.
Rear prop shaft was nice and tight, u/j's all seemed nice and tight and greased, no vertical or lateral play in driveshaft. Can rotate about 12 o'clock to 1o'clock.
Front prop shaft has a tiny bit of movement in it, but its clearly coming from u/j wear both the one in front of the transfer and the one behind the front diff.
Maybe a tiny bit more rotation possible but only 5 degrees more than the rear.
So I assume that degree of rotational movement is roughly normal??
So the question is where do I source my 2 replacement u/j's from, is it 'safe' to go after market or do I need to get from Toyota?
